I am having trouble tuning out a harsh 1-2 part throttle shift. The PCM commands 96% at low torque. See tune and log.
Tried another tune......no dice
TTT........ anyone
Possibly the shift pressure for the 1-2 shift being set to 150psi is doing it?
Yeah but not till about 250 ft lbs...... I have it set to 0 up until then. Any other thoughts?It seems to follow the table at WOT (it commanded 1.05 A once... Oops) but doesnt seem to do anything at very low input tq.
Yep that table is an adder to the base pressure table. So if you have just enough pressure to keep the trans happy but want a snappy shift you can play with the Upshift Adder tables. Enjoy!
Always Support Our Troops!
TTT on this one. I think the 1>2 upshift pressure modifier vs trans temp vs tq is backwards. I think the tq and temp need to be swapped. If so, I was commanding 96 with the adder table also, since the trans temp was normal operating temp (~160ish). I will test this again today.
Yep I thinkthis is the case. I softened up the 1-2 as if the tables were swapped and it was softer.
