Page 1 of 5 12345 LastLast
Results 1 to 20 of 97
Thread: RWTD - I took your suggestion on MAF only CL
    Advanced Tuner 69lt1bird's Avatar
    Oct 2007
    983
    I have seen you make this suggestion several times so I figured, what the heck, its nice out so let go try it. I set the Dynamic Air Hi/Lo Thresh to 0 and started driving.
    All I can say it, I should done this a long time ago. I smoothed the maf table a little and this thing runs great. I turned my LTFT back on, not sold on leaving them on yet, but I may drive it a while to see what they do. Some far so good.
    It even idles better, go figure.
    Free HP Tuners Beginners Tuning Guide
    LS1 Tuning Guide
    Michigan Snowmobiler
    1969 Firebird: 11.67@114 [email protected] 1/8 1.70 60 ft. EPS cam 234/246 .602.606 114+3, 6.0 LQ4, L92 heads milled 10.5:1, Ported L76 intake, ported 90mm Holley TB, 100mm MAF, FIC Custom injectors, Hooker LT, PYPES dual exhaust with an X pipe, 4L65e with all of the good parts inside, FTI 4000 RPM Stall, 12 bolt with 3.73 gears. HP Tuner tuned by me
    Jun 2005
    Southern FL
    2,044
    I'm glad it's working for you well (I wish more would try this). The MAF is always going to be accurate (once it's tuned in properly), whereas the VE can alter based on weather/conditions. Sure, there are correction parameters for VE for these variable conditions, but it's not the easiest to master without GM's equipment and testing methods.
    Formerly known as RWTD
    Toys: '22 Tesla Model S Plaid / '20 Chevy Duramax / ?20 Sea-Doo RXT-X (2)
    Feb 2008
    665
    Quote Originally Posted by RWTD View Post
    I have! I actually have been running my truck MAF only over the past couple of weeks and I am quite impressed with the way it has been running. The throttle response overall throughout the RPM range is very nice. I am actually OL MAF only and I am extremely happy with the way my truck is running which is saying alot because I am never happy with it.
    2017 Silverado LTZ
    Advanced Tuner midevil1's Avatar
    Feb 2009
    TX
    365
    Your MPG's will go up also.....I have seen up to 2 mpg in the trucks.
    2023 Ford Edge ST
    2020 Ford F150 King Ranch 5.0
    Nov 2002
    Central Florida
    2,503
    In my scanning I've seen the MAF frequency output be
    pretty unstable / jaggedy while Dynamic Airflow is nice
    and smooth. Are you convinced that this is just "noise"
    and motor runs OK? I am worried that if fueling follows
    too closely I will constantly be swinging lean-rich-lean.
    Maybe OK on average, but maybe more prone to sparse
    ping etc.?
    Feb 2008
    665
    Quote Originally Posted by jimmyblue View Post
    ping etc.?
    Do you feel that full speed density in open or closed loop will be much more consistent and responsive than MAF only or like the factory setup of a mix between VE and MAF?
    2017 Silverado LTZ
    MAF only? no VE? Please explain!
    Feb 2009
    TX
    365
    If there aren't any vaccum leaks in your intake tract ( i hope not) It doesn't get anymore accurate than MAF.
    2023 Ford Edge ST
    Jun 2005
    Southern FL
    2,044
    ping etc.?
    Jimmy, as you know, this of course depends on the type of CAI you have, and of course any MAF modification (screen, no screen, dremel grind?), or if there is any bends in front of behind, or any turbulence causing areas before/after. If the inlet is built properly then the MAF frequency will be nice and smooth. Small subtle jitters are expected, and the pcm has correction for this.
    May 2008
    24
    Wouldn't taking the "Hi/Lo RPM Threshold" table from the stock value of 2400 RPM to 0 RPM just give the MAF more (but not 100%) control?
    I thought the table that would give the MAF 100% control is the "High RPM Disable", which is set at 4000 RPM stock.
    Oct 2007
    983
    RWTD,
    Matt-B has a good question. I use the way I did it to tune the MAF only but also have it in ope loop, for truly running in a MAF only mode CL, should I just zero out the "High RPM Disable" instead?
    LS1 Tuning Guide
    Do you have a more detailed write up here? I'd like to try this..
    Jun 2005
    Southern FL
    2,044
    Quote Originally Posted by 69lt1bird View Post
    RWTD,
    Hmmm, how did you disable the VE actually? Yes, to run pure MAF just set the "High RPM Disable" to zero.
    Quote Originally Posted by Chuckster View Post
    Can you be more a bit more claritive in what you're asking? Are you asking for a "how to" on how to tune the MAF? If so, there's plenty of resources here using "Search". Sorry, not trying to sound like a prick, so please don't infer that.
    Nov 2005
    Houston, TX
    3,968
    I think Chuckster means how to run MAF only.
    On a 3rd gen it's accomplished by setting the engine/airflow/dynamic airflow/High RPM Disable field to an RPM below idle.
    Bill Winters
    Out of the LSx tuning game
    Dec 2006
    Rockwall, Tx
    247
    Its under Engine > Airflow > Dynamic Airflow. Set High RPM Disable to 0 rpm.
    Jan 2009
    Spokane, WA
    480
    What is the benifit or better yet, negatives to running pure MAF?
    In other words, why or why not would I want to do this? If it's such a good thing, then why isn't this way all the time?
    Do I also need to do anything else if I just "Engine > Airflow > Dynamic Airflow. Set High RPM Disable to 0 rpm"? I'm running a pretty much stock tune. Some PE/timing/shifting work, but that's about it.
    I'm new to tuning. Have no issues in trying something new if there is a benifit for it and I'm not going to mess something up. Know what I mean
    Jun 2005
    Southern FL
    2,044
    waynehartwig, what modifications do you have? Do you understand the concept of VE, as well as MAF, and how each are tuned?
    There really isn't any negative. Some would argue it's more accurate, easier to tune (it really is), and more stable (it definitely is this, as you set it and leave it, and you will never have to retune for outside condition/weather changes). The one potential downside is that if you disable VE and the MAF fails (like Germ-X, there's a 0.01% chance that'll you'll still have bugs on you, LOL), then the engine would not really run. If you have your laptop with you, that's not a problem (switch VE back on). Seriously tho, a MAF failing is about the same chances as gettings truck by lightning.
    When you say "some PE work", did you adjust the PE to obtain desired AFR WITHOUT adjusting the MAF transfer? If so, that's a no no. You set the PE to Command desired, and then you dial in the MAF transfer until that Commanded becomes Actual AFR.
    Quote Originally Posted by 5_Liter_Eater View Post
    Yes you are correct.. and thank you for being patient..
    I am JUST getting back into the tuning game after 5 years.. I know I sound like a dumbass newb.. But I Swear to god.. I used to help others tuning with the MAF Translator and logging with Autotap, then on to LS1edit.. Etc..
    Anyway.. I promise to listen and learn...
    So once the VE is disabled what is the next step in tuning? What am I logging at that point and what trends am I looking for? By the way.. I am in FL with the worst air in the country.. Does this still make sense to disable the VE?
    Jan 2009
    Spokane, WA
    480
    Honestly, I know enough to be dangerous - and even can call me a hack. I have next to no knowledge of it and the same limited experience. Just being honest.... I have engine building/tuning experience, but it's all old school distributor/carb stuff.
    I'll post my tune so you can see some of the changes I've made. But for PE I've cahnged the delay/enable RPM to 0, but upped MAP to 75 (from 55) and tightened up MAP HYST to 3. Oh, and I also changed PE Enable to 75% instead of 84% and the enrichment rate to 2% from .05%.
    I do have a wideband. So I disable VE and just use MAF. If I notice my wideband going lean/rich, do I just note when and go in and change the MAF calibration numbers to correct it?
    EDIT: just to be clear on the file name. The tune is a modified Edge tune. The biggest thing I changed was the spark tables, because I had a pretty good ping at partial throttle on hills. Give it a bit of gas, and the audible ping would go away. I also increased the timing under heavy loads a few *'s from Edge's.
    Jun 2007
    396
    Reversion associated with larger camshafts doesn't cause issues? My MAF does not track smoothly, not at idle, not @ WOT, not @ cruise. I've seen a few larger cammed cars have this same issue. My understanding is that this is why a lot of folks go to SD tunes...
    You've got my attention though. I'll go search a bit and see what I can learn on this MAF only tune concept.
    2011 Z07 Carbon Edition
