Results 1 to 2 of 2
Thread: Transmission Torque Management - Auto
    In the tables "Torue Reduction" under the Transmission/Torque Management, what would putting anything above 1.0 do in the Upshift and Downshift? Would it be to much for the stock tranny?
    Yes, its not uncommon to put higher values there. 1.25, 1.5 for the 1-2 shift, in the last columns. It'll make a difference, but you really need to adjust the shift points to make the best of it. It is possible for the truck to make more torque than is in the table (its calculated from the tables though) so a higher value can help. You need to up the pressure as well, and drop the slip times for the gears (shift change times). 1-2 and 3-4 need it the most, 2-3 isn't too bad, slip time-wise, from the factory but it can be tweaked as well for slightly better results.
    Having fun!
