Results 1 to 2 of 2
Thread: Fuel Guage Error - 2005 VZ Commodore Executive
    Advanced Tuner BigDaddyCool's Avatar
    May 2009
    Brisbane, Queensland
    767
    Hey guys, got a question with reguards to my dads car he's repairing.
    Got a 2005 VZ Commodore Executive. Long story short it has a "Fuel Guage Error" fault when the AC is switched on, the moment you put it into 'Run' the car immobilises (no start, no diag codes, no access to the computer).
    I tried a ORBII on it, no go cause of the immobiliser, cant run VCM Suite to basically download the ECU, turn the sensors off for it so it'll atleast start......... and also tried the relinking vats (for something to try).
    Cant do anything with it because of this issue. It's a repairable write off (not quite finished being repaired), so it's not able to be taken to Eagers for example to get reflashed/fixed/checked etc.
    Any idea's guys? I need to purchase additional credits to work with his car once i've read the ecu out but atm there's no point cause I cant even do that to see whats going on etc........
    Cheers
    Jamie
    May 2009
    767
    Just an update to this.... Is where any way to adjust the re-calibrate the fuel level stuff with VCM Scanner????....
    It'd be nice if it had similar abilities to the Tech2
