Thread: wiring help
    Guest
    Guest
    wiring help
    i have a 2001 LS1 throttle body, which i am installing on a 99 3800 s/c motor. I need the wiring for the TPS sensor?, it`s a three pin connector. also i have a mass air flow sensor from a 2001 chevy 8.1 liter truck, which i am using with thw LS1 TB. the MAF connector has five pin connector (two for the IAT sensor). does anyone have the wiring for the pin connector?. what i am looking for, is the labeling of each pin on the TPS and the MAF sensor.
    Sep 2002
    Chicago, IL
    6,395
    Re: wiring help
    From my 97 3.8 pinout diagram
    MASS AIR FLOW SENSOR
    A YEL - MAF SENSOR IN (Signal)
    C PNK - + (Power)
    B BLK/WHT - Ground
    Throttle Position Sensor
    C GRY - 5V REF (From PCM) (Power)
    B DK BLUE - TP SENSOR IN
    A BLK - Ground
    We got this guy Not Sure, ...
    Re: wiring help
    my 93 info has same pinout.. but diff colors. So just a matter of matching that to your harness colors since it looks like thats a GM standard configuration...
    Business Network Solutions - for all your PC, network, printer and computer security needs.
    Guest
    Guest
    Re: wiring help
    Now i need the wiring for the connector for the five pin on the 2001 8.1 leter vortec chevy truck?.
