Hello all. I'm almost completely new to tuning and have never tuned a Deisel but i would like to try it. I am ordering HPtuners Pro Friday as its the last thing i need for my LS1 swap and while i was reading up on the listed vehicles i see it supports Duramaxes too which i also happen to have. I was over joyed!
Right now my truck has a cold air intake (similar to K&N just metal), a 3.5" straight pipe exhaust (no muffler). I am running a Hypertech programmer on stage 3, and a PPE boost valve.
Truck is a 2001 4x4, 4 wheel drive, long bed, Allison transmission, with a few suspension mods for towing. I used to use this truck for towing alot but now it rarely gets driven. I just put new head gaskets, milled heads, re-sealed injector sleeves, etc so I'm not concered with problems in any of those areas.
What i am looking for is a tune similar to the stage 3 hytech which i think is something like 90hp. I still will be towing with this truck every now and then so i may keep a tune handy for towing but id really just like a stock tranny tune with similar power. I would also like a semi-safe tune for towing around 15,000lb trailers.
A few questions i had were
Can i adjust the grade-braking setting of the allison transmission?
Can i adjust the shift points and rev-limiter?
Can i adjust the converter locking points?
I am buying the setup regardless to tune my 68, but i am unsure if i want to waste 2 credits on my truck if im only going to get the same results as my hypertech programmer.
Thanks guys!
Shawn
