I'm tuning my friend Zach's truck that's a '06 with a 4L80E swap and we're seeing some weird converter lockup stuff at low speed. Basically sometimes in reverse the converter will actually lockup which of course causes the motor to bog and knock. Also, sometimes at low speeds like turning onto a residential street (5-10mph) the converter will lockup. If I give it a little gas sometimes it'll unlock just fine but otherwise it takes a second or so to unlock and go. Here's the specs on the truck:
'06 CC -
4L80E w/ Circle D billet converter 3500 stall
6.0 - MS3, full exhaust, intake
The transmission was built locally and from what we remember the stock converter wasn't locking up like that at low speeds.
In the log attached, where the knock spikes bad at frame 373 that's where the converter actually locked up in reverse. Kinda weird that it locked in reverse
Any help/insight would be sweet. I can't really find any threads on tech/PT/GMFS about converters locking prematurely like this.
