Thread: do cats affect AFR?
    Tuner in Training 346ci's Avatar
    Aug 2008
    37
    do cats affect AFR?
    Will mounting a WB O2 in the post catalytic bungs affect afr readings? I would like to take a quick look at a friends truck without drilling and welding another bung in. Thanks ahead of time for any input.
    Dec 2005
    Pinch, WV
    198
    I have found that, the bung in front of the CAT will produce most accurate readings. While using post CAT bung readings will be erratic during idle or light throttle.
    06 LQ4 2500HD CC LB 4wd 4.56, Dana 60,
    17 3500HD 6.0 srw
    GenIII Unlimited GM Full Size Truck/SUV
    Serial cable to WiFi
    Feb 2007
    San Antonio, TX
    1,255
    Yes. Almost .25 to .50 difference. If you choose to use the bung before the CAT you will have to tune in OL (Open Loop) only.
    Janky Monkey Tuning
    Call or PM for tuning solutions.
    Cell 210-954-4985
    Wrench turning provided by 2 Tightwads Racing.
    Tune your own? Start here ----> Open Editor ---> Hit F1...READ!
    READ SOME MORE (Thank username 69Lt1bird): http://ls1tuningguide.com/
    Still lost? Consult a Pro!
    www.thetuningschool.com
    www.calibratedsuccess.com
    www.tunedbyfrost.com
    Aug 2008
    37
    So my best bet would be use on of the pre cat locations and tune in open loop? This shouldn't be to big of a deal if I tune the VE before and then switch to OL to do WOT tuning?
