Results 1 to 11 of 11
Thread: Set max to 100 and min to 90
    Nov 2005
    Someplace high in the Himalayas
    770
    If you set the max pressure all to 100 and min to 90 under TCC duty cycle, will that cause the car to run slower in the quarter mile because the convertor will not flash as high?
    I have also increased the 3rd gear pressures because I heard it is hard on that band, thoughts?
    www.outlawpontiacdragseries.com
    Come race with us in MA, PA, and VA!
    2005 GTO A4 - Spintech X-pipe with Powerstick mufflers, IAT relocate, Volant, !scoops, !cowlgasket, !skid plate, LM-1, HPT2.0/MPVI Pro USB, 275x40x17 Nitto DR, rolled fenders, Pedders 2985 springs, Britax baby seat with 5 point harness.
    Stock:13.36@104
    Mods in sig:[email protected]
    May 2007
    489
    Nope Just Means It Wont Sssllliiippp Into Lock But Will Instead Just Lock Up.
    Nov 2005
    770
    What about increasing the base shift pressures for the upshift changes? Could the increased pressure pull the motor down and cause the car to run slower in the 1/4?
    Stock:13.36@104
    Oct 2008
    40
    Did you run slower in the quarter mile or something? I wouldn't think line pressure would slow you down at all.
    TCC pulse width only controls how much pressure the TCC is locking up with, like ws6 said. Exactly like line pressure with gears.
    Nov 2005
    770
    I'm looking for reasons why my GTO is slower on average than everyone else's. Most GTO run 13.0-13.2 stock. I run with one that is a freak that sees 12.70's with just a tune, UDP, and exhaust. Mine did run 13.0 once, and only once at Capitol in MD.
    No matter what AFR or timing (21-28*), my car does not respond, it runs 13.30-13.40. That's with exhaust, volant cai, Omega thermo, 160 thermo, pedders 1/2" taller springs, nitto 275's, and HPT. Perhaps mine is just down on compression? It doesn't burn any oil though.
    What AFR and timing would typically be good to get off the line, say 1000 rpm to 4000 rpm?
    Stock:13.36@104
    May 2007
    489
    There Are Alot More Factors To 1/4 Mile Times Other Than The Car, Like The Altitude, Weather, Humidity And So On.
    Have You Dynoed The Car Yet To Find Out Where Your Wot A/f Is At Yet?
    May 2007
    489
    Looking At Your Mods You Dont Have Any Real Hard Performance Stuff On Your Car So I Wouldnt Expect You To Be Making Much More Power Than A Stock Gto.
    Dec 2005
    214
    Different days different weather and DA.Most people just do not think about that,but weather has alot to do with your times
    Feb 2008
    665
    Quote Originally Posted by vortec View Post
    That is very true from what I have seen! My truck has run almost .5 second slower from a 90+ degree humid day compared to a 50 degree day with nice dry air.
    2017 Silverado LTZ
    Nov 2002
    Central Florida
    2,503
    TCC duty only matters when TCC is engaged. At
    WOT, should not be.
    Advanced Tuner 69lt1bird's Avatar
    Oct 2007
    983
    Post your tune up here and a log of the run.
    What mph are the supposedly comparable cars running? MPH in the 1/4 will let you know what kind of horsepower you are running compared to others.
    The TCC does nothing for drag racing like the others have said.
    What are your 60 ft times, 1/8 et and speed? A crappy 60 will put you way behind the others if they are better drivers or their car launches better.
    Free HP Tuners Beginners Tuning Guide
    LS1 Tuning Guide
    Michigan Snowmobiler
    1969 Firebird: 11.67@114 [email protected] 1/8 1.70 60 ft. EPS cam 234/246 .602.606 114+3, 6.0 LQ4, L92 heads milled 10.5:1, Ported L76 intake, ported 90mm Holley TB, 100mm MAF, FIC Custom injectors, Hooker LT, PYPES dual exhaust with an X pipe, 4L65e with all of the good parts inside, FTI 4000 RPM Stall, 12 bolt with 3.73 gears. HP Tuner tuned by me
