Changing shift points on 98 f body. WOT, Does it go off of speed or rpm? Can you turn the speed side of it off where it will shift only with RPM.
It Goes Off Of Both, And Make Sure The 100 Cell In The Part Throttle Map Matches The Shift Speed In The Wot Table.
