Results 1 to 5 of 5
Thread: Speedometer Corrections for 245/45/R17 Tires?
    Jan 2008
    Eastern Pa
    89
    Hey guys I own a 2000 Buick Regal GSE and stock my car has 225/60/R16 tires.
    Well I got new 17" rims and General Exclaim UHP 245/45/R17 Tires.
    I am not exactly sure what numbers I put into the Speedometer correction page in HP tuners.
    This is currently what is in my car now:
    My cars transmission has a 3.29 gear ratio and I must keep the sprocket ratio at 1.121 and calculated gear as 3.69 in HP tuners or I get an incorrect gear ratio error code.
    As of right now everything works fine however I am not exactly sure what number I put in as the "New" tire size. According to the companies website my tire has an overall diameter of 25.7". Should I put 25.7" into the new tire size and also 3.69 as the gear ratio?
    Also should I let it "Auto Scale Transmission tables" or keep that off?
    2000 Buick Regal GSE Ported Gen III SC with 3.0” Pulley, Northstar TB, ZZP Ported LIM, ZZP Stage III IC, Comp VS Cam, Comp 105 Springs, Viton Valve Seals, 42.5 Injectors, PRJ Gen II Fuel Rails and Racetronix Fuel Pump with HD Harness, TOG Headers with 3” Catted Downpipe, ZZP 3” Dual Stainless Cat-back, Dynotech Stage II Trans, 3.29 Final Drive, 2750 stall converter, GTP Engine Cradle Mounts, Front Motor Mounts Spun 90*, JMB 4” FWI, Autolite 104’s, 180* stat, GMPP Handing Kit, Moog Endlinks.
    Sep 2007
    Hillsborough NJ
    82
    I believe that you must put in the new tire size (diameter value) and leave everything else the same. Then press the Commit button. Now monitor your speed with a GPS and see if they match. If the speedometer reads higher than the actual speed then increase the tire size on the chart by the same % difference. If it reads lower then decrease the tire size by the same percentage difference.
    Jun 2009
    39
    On the VCM upper menu there is a Unit Conversion Option under Tools. This also have the utility where you can write the numbers of your tire and it calculates the tire height.
    Ivan
    Jan 2008
    Eastern Pa
    89
    I put 25.7 in as my new tire size and I think the speedometer is off just a little bit. I guess I will have to redo it with the number being a little higher/lower then 25.7.
    However when I did this I let it commit the transmission shift changes and man how much lower it dropped the mph shifts. Because of this my car shifts into 2nd gear even before I can go WOT. I am going to have to make changes to the table so over 50% TPS it isn't looking to shift at 37mph... too low!
    Jun 2009
    39
    When you get a higher rim, the car acceleration goes low (wheels turns slower), its like changing the gear to a numerically low one. Anyway, HPT automatically changes the shifting points very nice acording to your settings, but you can use the shift points settings your car have before the tire change (remember after a change save the file with a new name) copying from your backup file.
    Ivan
