Page 9 of 9 FirstFirst ... 56789
Results 161 to 177 of 177
Thread: Limplimplimp Be Gone!
  1. #161
    Advanced Tuner black06g85's Avatar
    Jul 2006
    New York, New York
    277
    so far so pretty damn good.
    2006 cobalt (no more turbo)
    m62 2.7 pulley, E85, 79lb/hr injectors, 4-2-1 longtube header, airbox mod, stock catback
    1998 Trans am 5.3 iron block 317 heads 88mm turbo e85 105lb/hr injectors, twin 255's.... build in progress
    2014 wrx mild tune 18psi pump gas
  2. #162
    Apr 2009
    32
    I set the "Boost Test Enable RPM" to 7000 rpm for both 60 & 100. Then turned the MBC til we got to 24psi and when I went to do a 4th gear pull on the highway, but after a few secs ALL Boost was cut...... help please....
    Ray
  3. #163
    I got some strange results:
    I'm running 25psi on my Solstice GXP with 16g turbo using the air load torque tables to control boost (modified GMP2 tune)
    Since I have already run 28psi with this tune and did not want to go higher, I went lower.
    I set the "overboost Allowed Error vs Desired Boost" table allowed error values to 20 at 7.3 thru 17.4 in an effort to induce limp mode. The car would not "limp" So I set these values to 18 and still no "limp" mode? There was no difference in performance after at least 15 boost runups in 2nd 3rd and 4th gears. No error codes either.
    What's going on?
  4. #164
    Quote Originally Posted by rtkjadams View Post
    Ray
    if you saw P0234 please contact support, if you didn't we need more details, codes etc.
    I count sheep in hex...
  5. #165
    Jul 2006
    New York, New York
    277
    odd, we were running 26.2psi on a gt3076 overboost test set to 8100 rpm. no underboost or overboost codes thrown yet all week, and believe me we tried lol. 5th gear 2000 rpm pulls multiple time to try and trip the underboost, nada.
  6. #166
    Quote Originally Posted by black06g85 View Post
    that would of def. set an underboost code because I fought that with my setup
  7. #167
    So HPT at this time can't raise boost by using the ECU in a 97 GXP? You would need to use a MBC? Is this correct?
  8. #168
    Mar 2009
    676
    Uhmmm... i think were talking about different ECU's there buddy.
  9. #169
    Quote Originally Posted by mkriebs View Post
    Sorry 07 GXP, 97 did not exist
  10. #170
    Mar 2009
    676
    Oh haha! I was thinking GTP for some reason.
  11. #171
    Apr 2009
    32
    Quote Originally Posted by Chris@HPTuners View Post
    No codes..... what kind of info do you need?
    Ray
  12. #172
    Sep 2008
    Los Angeles, CA
    19
    -Deleted-
  13. #173
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,266
    Quote Originally Posted by Squier View Post
    Tried installing and I keep getting:
    Error 1901. Error attempting to read from the source installation database:
    C:\WINDOWS\Installer\2e78b7.msi
    According to google yhou have an antivirus problem that needs to be fixed, its not a software issue on our end.
  14. #174
    Ray
    anything in a log that might help me understand why it is being cut. ie. throttle closing, BOV, anything that will help me.
    These new params only address the P0234 Overboost and P0299 Underboost DTC's
  15. #175
    Sep 2008
    Los Angeles, CA
    19
    -Deleted-
  16. #176
    HP Tuners Support
    (foff667)
    28,266
    I also saw spybot mentioned.
  17. #177
    Advanced Tuner GeoffH's Avatar
    Jul 2009
    Panama City, Florida
    344
    What are you guys setting the Underboost set/clear and hyst to?
