Results 1 to 11 of 11
Thread: Car wont shift 1-2 at WOT?
    Tuner in Training CAMAROZ28AQUINO's Avatar
    Apr 2008
    North Bay, Ontario
    40
    Hey guys car wont shift at wot until i back out of the throttle, just bounces off the rev limiter. Car has full exhaust cam, 3.73 gears and tci 3000 stall. what is wrong with the tune?
    Copy of the tune is attached. thanks
    1998 Camaro Z28 A4
    18x9.5 C6 Z06's |SLP Lid | Pacesetter Lt's | Custom Catted Y | Corsa Catback | Cutout | TCI 3000 | 3.73's | Comp 228/232 .588/.595 110+4 | PRC Duals | 7.425 Pushrods | Hp Tuners |
    i have the same prob right now in a 2007 silverado.. hits the rev limit everytime before shift.... shift is set at 5800.. and rev limit at 6500.. i have procharger ,cam , and fully built trans with 3000 stall
    Apr 2008
    North Bay, Ontario
    40
    Im not sure what is causing this but im sure someone will help us out
    1998 Camaro Z28 A4
    Dec 2007
    776
    Quote Originally Posted by CAMAROZ28AQUINO View Post
    One approach is to send your timing off a cliff at the rpm you want it to shift so that it sees a torque reduction.
    There may be others, but this one has been proven to work.
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,214
    If your using stock dia rear tires, the tire/gear field should be 6.68. Also log the trans output revs.
    Russ Kemp
    Apr 2008
    North Bay, Ontario
    40
    Quote Originally Posted by Russ K View Post
    Russ Kemp
    hey russ, the car has 275/40R18s all the way around. Ill log trans output revs tomorrow with your config
    1998 Camaro Z28 A4
    Dec 2005
    Regina, Sask.
    4,214
    Then with your 275/40/18 tires, use 6.95 in the tire/gear field.
    Russ Kemp
    Dec 2007
    776
    Russ Kemp
    Do you mean 6.95 in the "Gear" (ratio) field, and leave the tires at 26.7" (275/40/18) for example?
    Thanks!
    Apr 2008
    North Bay, Ontario
    40
    Russ Kemp
    Hey Russ, how did you calc 6.95?
    I got 7.16 (26.7 / 3.33)?
    Is this correct?
    1998 Camaro Z28 A4
    Aug 2008
    34
    are you sure its the tune and not that trans? sometimes they will bounce off the limiter if the trans is on the way out.
    Apr 2008
    North Bay, Ontario
    40
    trans is mint man. car has like 30k miles and never raced it shifts perfect except for that i know the tune is out. But i do know that 4l60Es are crap and die easily but this ones still good.
    1998 Camaro Z28 A4
