Hey guys car wont shift at wot until i back out of the throttle, just bounces off the rev limiter. Car has full exhaust cam, 3.73 gears and tci 3000 stall. what is wrong with the tune?
Copy of the tune is attached. thanks
1998 Camaro Z28 A4
18x9.5 C6 Z06's |SLP Lid | Pacesetter Lt's | Custom Catted Y | Corsa Catback | Cutout | TCI 3000 | 3.73's | Comp 228/232 .588/.595 110+4 | PRC Duals | 7.425 Pushrods | Hp Tuners |
i have the same prob right now in a 2007 silverado.. hits the rev limit everytime before shift.... shift is set at 5800.. and rev limit at 6500.. i have procharger ,cam , and fully built trans with 3000 stall
Im not sure what is causing this but im sure someone will help us out
1998 Camaro Z28 A4
If your using stock dia rear tires, the tire/gear field should be 6.68. Also log the trans output revs.
Russ Kemp
1998 Camaro Z28 A4
Then with your 275/40/18 tires, use 6.95 in the tire/gear field.
Russ Kemp
1998 Camaro Z28 A4
are you sure its the tune and not that trans? sometimes they will bounce off the limiter if the trans is on the way out.
trans is mint man. car has like 30k miles and never raced it shifts perfect except for that i know the tune is out. But i do know that 4l60Es are crap and die easily but this ones still good.
1998 Camaro Z28 A4
