Originally Posted by
MonkeyGod
Some questions about knock and detonation...
Is it possible to have detonation in a motor, without any knock detected either via noise or the knock sensors? (assuming the sensors are working correctly)
How would you determine if detonation is occurring without these outward signs? Can you read the plugs maybe?
It is possible detonation could damage a spark plug? Causing the ceramic to crack and fall apart?
If you switched from an aluminum block to an iron block...would the stock knock sensors no longer work? I know that GM often released both iron and aluminum blocks in certain model years (esp trucks), but I can't seem to find out if they released different knock sensors for those, or had a different calibration in the tune file to compensate. Any thoughts on that subject?
Thanks.
