Hey, been trying a couple things that I know how to do, been having a heck of a time getting it to idle.
It does these things:
*Surges cold start
*Surges warm start (not as bad)
*Will cut off in P/N after a quick rev to 2500 rpms (idle drops low, surges, dies)
*Will cut off immediately when put into gear.
* will idle IF and only if i play w/ the throttle for a while and it will only idle clean after doing this when hot.
Tune is attached.
Specs on car:
408 Iron Block (6.0 bored .30 over)
12:1 Compression
Trick Flow 215 Heads
Cam motion 243/245 650/650 112lsa
fast 90/90 intake
reg. tb... wire driven.
90mm tb
85mm maf
255lph walbro
42# inj.
61 psi fuel pressure
kooks 1 7/8" lt headers to 3"
