Hello ,
Thanks for reading my posting.
My, 02 camaro Z28 is throwing 02 sensor codes indicating the right front sensor is bad. I replaced both sensors and the problem remains. The wierd thing is that the engine service light will continually flash at an idle; but goes off when I start to drive. I pull up to a red light it will flash again, I leave the light it goes off. I swapped the sensor with two other 02 sensors and they all do the same thing. I'm ruling out the sensor; but what else would do that??? This may mean nothing; but when I had the car Dyno Tuned the tuner mentioned somthing about low voltage to my throttle position sensor. Would that make my engine light flash constantly only at idle and throw 02 codes??? What can I do???
I'm Lost!!!
Scott
[email protected]
