Why ??? Because it have some confusion between you and greg.
You multiply by 0.88 and do not substract the shaft area
And greg substract the shaft area and did'nt multiply by 0.88
In my sens that make a bigger difference than +-200
90mmTB: (3.1416*45*45)=6361.74
90mmTB shaft 10mm assumed : (90*10)=900
So 90mmTB :6361.74-900 *88%=4806
ETC=4806 vs my Hp tuner value at 4725 are pretty close
For the 2009 TB I did'nt think that GM put a bigger TB. What do you think If they put 5636 just because they assume that the 88% is in reality 100%
That would give:
90mmTB: (3.1416*45*45 ) =6361.74
90mmTB shaft 10mm assumed ( 90*10)=900
So 90mmTB :6361.74-900=5462 for 100% opening
ETC=5462 vs Hp tuner value at 5636 are also pretty close.
102mmTB: (3.1416*51*51)=8171.3
102mmTB shaft 10mm assumed102*10)=1020
So 102mmTB: 8171.3-1020=7151.3
As for the NW 102mm TB I think that the correct value should be for C6 Z06 2008: 7151.3*88%= 6293
For 2009 car's: 7151.3*100%= 7151.3
Let me know what do you think,
Later,
Sébast
