Got a 1996 3.8 Camaro, with a 97 pcm. When I'm on the highway holding steady throttle, it'll suddenly peg my WB rich or lean (random). If I let off the gas, or bump the throttle just a bit, it'll pop back to where it should be, but not for long. On occasion it tries to die, or looses power as a result of this. In the case of pegging rich, I'm told that it starts blowing a gas cloud out the tail pipes. This problem has been around for a long while, during the duration of this problem I got rid of the cat, and unplugged the egr (made all necessary adjustments for this I believe). Driving around town is fine. I'm entirely lost on this problem. Another person on another forum is having the exact same problem, he figured out that if you force open loop (by setting the CL enable temp high) that it runs fine, no problems. He also said the he replaced the MAF, MAP, 02 sensors, PCM, and several other items to no avail. I tried forcing OL myself, and got the same results as he did. Both cars have 97 pcms, the difference is that his has a holden intake conversion vs my engine is still bone stock, same exact problem with both.
Is there a hidden table in HPT that I can't see possibly? I have HPT pro and an AEM UEGO WB plugged into it. I really need help with this problem, this is my main source of transportation.
I have attached a scan and the tune to go with it, this is before I learned about forcing open loop.
