I have been doing a ton of reading and I just keep getting more confused.
I am trying to get my PE to reach a consistent 12.8 A/F at WOT. I seem to have to make huge changes in the PE table to get it to lean out. I am raping the PE table so that I can run at the track tonight. It's apparent that something needs to be tuned but I can't figure out the issue. I've read about open loop and some have mentioned a value of 10 being in the OP EQ Ratio table. I have 10 in this table now as well as stock.
I have FAST 46lb injectors. Does it appear that my injectors are scaled correctly? I have my LTFT turned off so that I could see what the gauge is displaying for STFT. Some spots it pulls as much as +14 and some spots it goes -15ish. So it seems I need to work on my fuel trims.
I have a wideband hooked into my gauges. However, I don't have the pro version of HPT...I can however log my A/F via my gauges. Right now I'm seeing 12.4.12.7ish until about 5600 where i can't seem to get it leaner than 12.1ish. I have had to change the ratio to as low as .958 in the PE table. I'm scared something is going to go haywire and blow up. My commanded A/F doesn't seem to change beyond 14.7.
Please help me figure out the steps to correct this.
IE....
1) Check scaling of fuel injectors....correct?
2) Tune MAF....how?
3) Set PE to 12.89 commanded...?
4) Tune VE...if needed, how?
Thanks.
