Page 8 of 8 FirstFirst ... 45678
Results 141 to 155 of 155
Thread: Reading WB02 with HPT Standard, using AC Pressure Switch
  1. #141
    Feb 2009
    418
    The user defined PID that I cant edit or do anything to is:
    100*([SENS.120]-[SENS.121])/[SENS.121] and that gives me a read out of 50% to 75% error.
    My AFR error is the one leafy posted up in post #123.
  2. #142
    Nov 2005
    Houston, TX
    3,968
    I don't have any experience tuning with E85 but I understand that a wide band configured for gas will show 14.7 when the sensor detect stoich. So 14.7 really equals 9.7. So if you are showing 10's you are super duper rich.
    You should reconfigure the LC to show stoich for E85 and/or switch to lamba to remove some stuff from the equation.
    Bill Winters
    Out of the LSx tuning game
  3. #143
    Feb 2009
    418
    Quote Originally Posted by 5_Liter_Eater View Post
    Ok, I will change that and let you know the outcome.
  4. #144
    Feb 2009
    418
    Ok I left my terminal plug at home so I change change the stoich just yet.
    As for the ARF error the equation posted in #123 is only showing an error of .5% even though I am fueling 10.0 gas so something is wrong. Is there another equation I can use or something else to use?
    The thing about going from ~14.7 to ~9.7 on my WB gauge is still throwing me for a loop on this. The % AFR off would be the same I would think no matter what fuel you have. So the output % on the log should be the same. Only thing that might change is the function.. Which I still have not figured out.
  5. #145
    Feb 2009
    418
    I was thinking why can't I do a 100*((USER.xxxx-14.7)/14.7)? User.xxxx represents the custom afr pid.
  6. #146
    Feb 2009
    418
    Alright, that function I wrote above worked well. Seems to be a lot easier than the other error posted. Why do another calc with the ac pressure volts when you just take the actual AFR (since it already calculated what the volts were in AFR) it is recording and make you equation?
    Anywho I am still running the gas stoich on the WB too.
  7. #147
    Jul 2010
    371
    glad that worked for you, for some reason it didnt work for me on 2.22, maybe it will work now that I'm on 2.23.
    1994 Mazda Miata turbo, aero, hoosiers Class=SSM
    Take my drop box referral and we both get an extra 250 Mb free!
  8. #148
    Nov 2005
    Houston, TX
    3,968
    You cannot reference user defined PIDs in other user defined PIDs in 2.22. the built in Air Fuel Ratio Error PID should work fine in 2.23.
    Bill Winters
  9. #149
    Feb 2009
    418
    Well it wasnt working, the error was not correct.
    I made my AFR error user defined PID reference my AFR user defined PID and it works great.
  10. #150
    Nov 2005
    Houston, TX
    3,968
    You said in post 140 that you were using a custom AFR Error PID. Try using the built in "Air Fuel Ratio Error PID". It's not editable.
    Bill Winters
  11. #151
    Feb 2009
    418
    Yes I am because last I remember I used the built in PID it wasnt the correct error. I will try again.
  12. #152
    Feb 2009
    418
    The built in AFR error does not work. In a cell that is reading -3.21 on my PID the built in is reading +78...
  13. #153
    Nov 2005
    Houston, TX
    3,968
    Thats weird...
    Bill Winters
  14. #154
    Feb 2009
    418
    Thats weird...
    Very.. That is why I made my own. Some spots were over a hunder error. The PID I made is working, as I can tell, perfectly. So whoever needs it, if there built in PID doesnt work, feel free to use it and let me know.
  15. #155
    Tuner thebucky84's Avatar
    Sep 2009
    SoCal
    146
    is the red/black wire from a/c to the pcm on the top wire harness on the pcm?
    2011 CTS-V Coupe
    - 1993 Mazda RX7
    *The most powerful designs are always the result of a continuous process of simplification and refinement.*
