Results 1 to 6 of 6
Thread: Tcc Pwm
    Advanced Tuner Blue02WS6's Avatar
    Jul 2006
    Central Florida
    319
    Tcc Pwm
    I have read that it's good to disable the PWM if you have a aftermarket stall and to set the duty cycle max to 100 (max) and some say the min needs to be set to 90 while others say to set it to 99...would seem to me that setting the min to 90 would still let a little slip, is this for safety?
    2002 WS-6, Built A-4, 3000 stall, Lid and K&N, ported TB, 220/224, .551, 114 LSA, roller rockers, LT's, 2.5" true duals with X-pipe, Koni adjustable front and Bilstein rears with Hotchkis springs, front bar and bushings, welded SFC's, boxed LCA's., Midnight Blue trimmed in silver, silver face gauges, custom hood bird, HPT (with lot's of tuning)
    Mar 2009
    Andover, MN
    457
    I have the same question, lol. I am running a Circle D triple disc in a 4l80e.
    May 2004
    AUSTRALIA
    839
    Why would you want an aftermarket converter to slip during lock-up?
    Nov 2002
    Central Florida
    2,503
    I set max to 99 and min to 98 myself.
    But you also need to be sure whether 99% of
    not-enough (main line, 0% commanded at cruise)
    is anything but not-enough (trick question). Of
    course it will be better than 30% of not-enough,
    or whatever "slip learning" silliness is there now,
    but you may have more work to do than just the
    obvious.
    Jul 2006
    Central Florida
    319
    Quote Originally Posted by MNR-0 View Post
    I don't really know how the converter is designed to work and what is the best way to work.
    Jul 2006
    Central Florida
    319
    Quote Originally Posted by jimmyblue View Post
    obvious.
    Jimmy...What do you mean?, can you explain in plain English that a lay person can understand.
