A possible customer installed a TVS 1900 on his LS2. He had to send his computer to them for tuning. Can I use the software to read and flash this computer or will it have to be reflashed back to stock first?
you should have no problem with that. magnuson does not lock their tunes as far as I know.
Thanks for your input
So I can just suck the current magnuson tune from his computer to license it and then modify it and reflash it without any problems?
yup. just curious, what vehicle?
It’s a 2006 GTO M6.
Thanks again
He is unsatisfied with the performance of the conservative magnuson tune.
He is very satisfied with drivability but apparently it won’t break tires loose in second gear.
the tune magnuson has for the gto tvs kits is a mess, in my opinion...(at least the one I was sent by them)
The only mod this car has is the blower everything else including the tires are factory.
What is the ideal AFR for this setup?
again, thanks for any input
from my understanding you should be around 11.5afr on that application.
all my gto had was a K&N cold air kit and a custom flowmaster exhaust. so it seems there is something wrong with this one
Thanks again
Apparently he took the screen off the MAF while doing the install. Anyway, his main gripe is bad throttle response so the MAF probably needs tuning.
throttle response is improved mainly via the VE tables...luckily enough, you may have the old style VE tables
Bader Norris
MEP Tuned
Telephone: +965-55446651
Email: [email protected]
if he removed the screen out of the MAF then yes you do need to tune it. the best option would have been to leave the screen in.
06 GTO M6: flowmaster 40 mufflers, x pipe, resonator removed, K&N cold air kit - sold
08 G8 GT: flowmaster 50SUV mufflers, x pipe, resonators removed, ever changing tune, CAI sometime soon.
I plan to look at the VE table first then do the MAF. I just hope everything is right with the blower install.
Your input is greatly appreciated.
Could you explain how to tell the difference in the MAF tables?
My late 05 GTO has a VE table that uses bigger numbers than my 98 Z28. I presumed it was the virtual table. This will be the first 06 I have tuned.
not a virtual ve table, just a different way of representing ve. (GMVE) Tuned the same way as the older style ve.
just fyi, from experience with the magnuson tvs tune for a gto, if you plan on doing any tuning at all, you may just want to scrap that tune and work off the stock tune. the way they adjust fuel via the injector offset table will have you chasing your tail trying to adjust maf/ve.
sunny, do you mind posting the tune? im curious if magnuson changed the tvs tune significantly from when I received one...
subscribing
Joe
2006 M6 GTO
APS TT
10.76@131
"The goal of tuning is for the tune to run well enough you dont need any corrective mechanisms"
Took a look at the tune. Below are some things I saw I didnt think was right.
1. The richest the PE was commanded was 13.3 except above 6500 where it was 12.1 (rev limiter set to 6600 rpm)
2. The tune is still set up to use fuel cut-off as the rpm control method
3. VE only increased in 99 and 105 kpa columns from 4400rpm and up
99 kpa 105 kpa
0.12500 4.68750
36.25000 40.81250
72.37500 76.93750
108.50000 113.06250
144.62500 149.18750
180.75000 185.31250
216.87500 221.43750
4. I'm pretty sure the IFR table isnt set up correctly. It only has two values: 62 and 63.09
Things I dont understand:
1. Changed dynamic airflow high rpm disable and re-enable from 3600 and 3500 to 2200 and 2100 respectively
2. They made a lot of changes over a stock file that I dont understand. Not to say they are bad just dont know what they affect. Purely a lack of knowledge on my part
Joe
2006 M6 GTO
APS TT
10.76@131
They just don't know WTF they are doing, that's the short answer of it. If I were you, I'd ditch their shitty tune and start from factory and build your own, NOT raping the PE table, and having MAF and/or VE dialed in properly.
Formerly known as RWTD
Toys: '22 Tesla Model S Plaid / '20 Chevy Duramax / ?20 Sea-Doo RXT-X (2)
