Results 1 to 14 of 14
Thread: O2 Sensor Questions
    Tuner in Training Bumblebee06's Avatar
    Aug 2009
    14
    O2 Sensor Questions
    I recently had LG Pro headers put on my C6 but didn't have the o2 sensors at the time. I had stumbled on a post that had a walkthrough on how to disable them and did so with success. This is on an LS2, A6, 2006
    Now I have the front two sensors in and working but they are still disabled via the the tune.
    I do not want to reinstall the rear ones if I don't need too so question one is does this pose a problem to the ecm to only run off the front two?
    Can anyone tell me the optimal way to enable the front ones while still leaving the rears off? I know the DTC's with Bank 1 need to be enabled again but looking for any additional help anyone can throw my way.
    Sidenote if anyone can point me to that elusive post that I can't seem to find the correct search words that discussed this topic that would be great.
    Thanks!
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,860
    Disable any code that references the Sensor 2 stuff. When I get home, I can e-mail you the file from my friend's 2005 so you can see the codes that are disabled. Leave SES Enable checked, but set them to 3.
    There's no problem to turning off the rear O2 sensors. The only purpose they serve is to monitor catalyst efficiency. If you don't have cats anymore, then there's no point in having the rear sensors. Only your fronts provide input for fueling adjustments.
    FYI, check your PMs on Speed.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Jun 2005
    Southern FL
    2,044
    To disable COT and the Rear O2s:
    Engine, Fuel Control, COT, Lean Cruise, Cat Over Temp Protection:
    COT - Set to Disabled
    Engine Diag, General, Catalyst:
    Catalyst Test - Set to Disabled
    Post O2, Post O2 Test - Set to Disabled
    Engine Diag, DTCs:
    Set all the below DTCs to Error Mode "3 - No Error reported".
    P0036
    P0054
    P0056
    P0060
    P0137
    P0138
    P0140
    P0141
    P0157
    P0158
    P0160
    P0161
    P0420
    P0430
    P2A01
    P2A04
    Formerly known as RWTD
    Toys: '22 Tesla Model S Plaid / '20 Chevy Duramax / ?20 Sea-Doo RXT-X (2)
    Mar 2008
    St. Louis, MO
    4,860
    I thought unchecking SES Enable didn't allow the readiness checks to complete.
    Jun 2005
    Southern FL
    2,044
    That's possibly true. I've never attempted to verify this.
    Aug 2009
    14
    Thank you!
    Mar 2008
    St. Louis, MO
    4,860
    Quote Originally Posted by RWTD View Post
    I'll try it this weekend when I tune my buddy's 05 Corvette. I only vaguely remember reading about it.
    Oct 2009
    Massachusetts
    183
    I know I'm bringing back an old post, but was the verdict? My inspection will be in a few months and I've got the rear 02's turned off by setting all of the DTC's described above by setting them to: 3-No Error Reported, but I have SES Enable unchecked . So far everything seems fine, just want to make sure it's ok for inspection. Is there an easy way I can test it myself?
    Mar 2008
    St. Louis, MO
    4,860
    Just check your readiness monitors in the scanner.
    Nov 2009
    houston tx
    91
    Hey guys sorry to bringing this thread back, but I have a question will this setup work for a 2006 gto, I went ahead and disabled my o2s I unchecked the box and change to no error 3, disabled cot, but on the status bid It shows that its on. That can't be true since one of the rear o2 is not even there, its plugged off.
    Mar 2008
    St. Louis, MO
    4,860
    The status bit shows that what is on?...
    Nov 2009
    houston tx
    91
    The rear o2s
    Mar 2008
    St. Louis, MO
    4,860
    The PCM is still going to try and activate the sensors... they just won't throw any codes.
    Advanced Tuner Niemer's Avatar
    Jul 2012
    371
    Don't set COT to disabled if you have DOD/AFM and you want to use it. Just set the enrichment to 1.000 and max out the enable temp. table.
