ok what i have in the shop is a 2004 GTO. i have replaced the Oil pressure sensor cause the oil warning keeps coming on, and the pressure is fine. then it is throwing the p0641. so after checking all the sensors they all read a little low. so i replace the computer still get the code. now i go and check the wires and they are all over the board. map is 9V OP is 7.8 AIR CON is 4.2 makes no scene. put the other computer back in and it doing the same thing.
ok so the car will act fine for the first few ins and then all of a sudden the oil pressure will go from 70 PSI to - readings. then just slowly count up and up and up. also another issue we are heaving is the coolant is always going off that its low.....LOL..there is more bugs in this car than i have ever seen.
so to try to fix this we have
checked all the volts at all the sensors, and tried to narrow it down to one of them
replaced the computer
banged head on wall.........
im out of ideas. and the grounds are all on too. and throwing no other codes
and the scans look good...so any ideas?
