Results 1 to 3 of 3
Thread: Cannot open .cfg files from here
    May 2009
    49
    or anywhere for that matter. every time i try to open a .cfg file it will open the scanner and say "unable to parse log."
    i am having troubles with my LC1 WB, and have tried opening a couple .cfg's that ppl have posted to help me out, but every time is gives the same "unable to parse log" message. why is this?
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,268
    Its because .cfg files are a configuration they are NOT a log hence you cannot open them as such, you need to open the scanner then either click & drage the SAVED config file into the scanner or opent he scanner & click the file-open config drop down.
    Jan 2010
    North Carolina
    29
    I got the problem 'unable to parse log' and tried the click and drag, but it will not let me drop it in the scanner. I also have some saved but when I do the file open from the scanner, I can't find the file. The only way I can see them is if I open the hp tuner from my documents. I'm not understanding something?
