Results 1 to 12 of 12
Thread: "A6 Help" After 3600 converter install
    May 2008
    7
    After installing Yank 3600 2006 C6 A6... The car leaves the line hard for about 3ft. then falls on its face, and then recovers..
    Any help would be greatly appreciated...
    Advanced Tuner madvette08's Avatar
    Jan 2009
    Tampa, FL
    427
    Can you post up your tune file.
    thanks
    Ian
    2008 Corvette A6 - Comp Cams 231/239 617/624 109 ICL 113 LSA, Patariot Extreme Dual Springs .660", Milled .30" Stock LS3 Heads, Mahle -4cc pistons, FTI 3600 Converter, 1 7/8 kooks cat-less 3 inch X-Pipe, air raid intake, ported TB, SLP Loudmouth I. 512hp/464tq
    2011 Ford Taurus SHO - stock with just a Tune
    May 2008
    7
    ok.. here it is
    Jan 2009
    Tampa, FL
    427
    Thanks having a look at it now.
    Ian
    Jan 2009
    Tampa, FL
    427
    Have a look at this tune file just the tranny settings, its setup for a 3600 stall converter, only difference is it has 2.73 gears and its a 08.
    Ian
    May 2008
    7
    wont let me open it says "Index outside the bounds of array?"
    Jan 2009
    Tampa, FL
    427
    Sorry its because i have beta, ill post up some screen shoots of what i have done to the tune.
    Ian
    May 2008
    7
    thanks..
    Jan 2009
    Tampa, FL
    427
    Heres what i did with the TCC settings, i did this Normal, Pattern A and Pattern B and TUTD if you the paddles at all. I also bump the shift pressures up 10 psi in Base shift pressures X, Y and the max line pressure and brought all the base shift times down to .2002.
    Ian
    Jun 2007
    Close to my Z06
    271
    Quote Originally Posted by madvette08 View Post
    Ian
    Ian
    I am helping a friend with his A6 06 modded Tranny with yank 3000, would your tranny settings work fine for that as well? His will end up with high SC boost.
    What changes would you have to do if a stock torq converter was in use?
    thnx
    May 2008
    7
    Im still having issues, when I use ET street tires (slick).. The car falls flat upon launch,then recovers quickly,and takes off? Also sometimes it will not shift 2-3 without letting off throttle?
    Feb 2006
    Canada
    1,963
    (Shift issue)Bry, are you compensating for the tire change in your tune? Also, do you have your shift speeds matching in both Normal and WOT at 100%? In Normal Shift even make the last two colums match your WOT shift points.
    (Launch issue)Throttle Cracker table a little lean?
