I would like to use the 2.5bar OS on an 06 Z. Anyone successfully use an 07 ecu for this? Thanks.
I dont wanna sound like I know best, but damn we changed the VIN on my 08 ECU to an 07 when I had the same problem of trying to get the 2.5bar SD to work on my car, it was a total failure.
I was told however that the newer models were the problem, they had so many security checks it was almost impossible, we changed the ECU's VIN, and that didnt match with the VIN in the other vehicle modules so it wouldnt goto ignition,crank, accessory mode nothing.
I personally think its not the ECU, but the 06 VIN that wont allow you to use it, but who knows. Goodluck
Well, I flashed an 07 2.5bar file to his 06 ecu just to try it. Sending it back to him today so I should know in a few days if it's going to run ok or not.
(After flashing in the 07 file I was still able to scan/connect so that's a plus)
I'm interested as well in what you did for the VIN number...
http://www.dsxtuning.com
Just say no to bull s***.
I didn't change the vin, it kept the original 06 vin. After I flashed it I read it again and it said something like invalid vin/os please contact for support flashing disabled but I can still make changes to the file I originally flashed it with and it accepts it.
Again, not sure if it's going to work but I thought I would give it a try.
jimmy just checkin in
Customer called today and said the car seems to run well which is a plus but still can't say 100% success until I have it in my hands. (which may be a while as he has an oil pressure issue).
nice to hear that did work with hem ,, let us know what happen because i have 2006 that i need to put speed density tune in it with custom OS .
sounds positive so far
just let us know
Nice work man, I have been trying to find a pinout diagram on both so I wouldn't fry anything before trying this. I will post my results as soon and my heep is running again. lol
Your wish is my command! I just made these for you from our Mitchell account.
2005, 2006, 2007, 2008, and 2009 C6 engine performance wiring diagrams:
http://www.diablosporttuning.com/fil...g_diagrams.zip <---right click, save as please!!!
Formerly known as RWTD
Toys: '22 Tesla Model S Plaid / '20 Chevy Duramax / ?20 Sea-Doo RXT-X (2)
Awesome!!
It looks like there are at least a dozen wires that are different so far between the two pcm pinouts, most critical it looks like map sensor and ignition voltage wires are not going to the same place as well are oil switch, and a few others. My first assessment is the conversion from 07 to 06 OS is not compatible, and wont run right unless the harness is modded. I will continue crossing the two some more tommorrow but thats all I came up with today.
im going to contact the guys at FROG harness's, [email protected] . and send them the pinouts, and see if they can make an adaptor harness, probley gonna be about 300 bucks.
-carl
