I have to put a set of dual fans on a 08 Z06 and just wondering if anyone has done this. Looking on how to wire them in and also fan tuning suggestions would be greatly appreciated.
TIA
Brian
TIA
Brian
Brian Delaney
Corvette Concepts.com
1999 Corvette FRC New Set up LS3 418 527/497
Old set up 346 NA 448/416 11.33@124 1.68 60'
2008 Corvette M6 Bolt-ons. 11.88@119
2005 Silverado 5.3 Ext cab Intake and Tuning
2000 Corvette FRC Heads and Cam
I wired both of them into the single factory relay (fan control) and running at 100% for a few days, that thing gave up >.<
I now have them come on with ignition, and wired with the stock pump, so when the pump stops priming, they would stop as well untli the car comes on.
Ideally, for me at least, since I want them running ALMOST at full speed the whole time, ill buy a thermostat switch, cut through the radiator hose containing the hot coolant, and have that trigger the fans at a preset coolant temp.
Im sure there are other better ways though.
You might want to look at the fan controller from an 07+ truck as they have dual fans. Then set up your fan settings like the truck.
Always Support Our Troops!
