well, the thing is... yes I've tried setting to what you're suggesting (3.42 ratio and 17 pulse per revolution) but that only results in the speedo pegging
I've played with that to no end and don't seem to have any clear notion as to what to do.
If I select the Vehicle Speed Output to RepTOS - it simply doesn't make any difference, that is, it doesn't do anything.
How could I go about modifying the PPM output? Can I re-configure segments of the installed e38 OS somehow? To, perhaps, enable the PPM output options? I would imagine that it's similar to any other hardware OS in that you have certain switches that turn things on or off for various configurations, A6/M6/A4 etc.
Also, surprise, the pin for the Reverse Lockout Solenoid does not work - is there anything that I can do about that?
I refuse to believe that there is nothing that I can do to fix this.... every other gauge works BUT the speedometer. Even the oil level sensor! haha.
edit: I also looked at the stock hpt file for a 2004 GTO M6... the VSS pulses per rev looks to be set at 40?? Strange...
