Do you think its a good idea using 09 A6 calibrations in earlier A6s? Also, how would you tune an A6 with higher stall speed, like 3000?
nothing i have found so far i also reduced TM after trying it to make sure it worked ok
may experiment with higher pressures for a firmer shift at part throttle later on
and yes on the stf (.5000)also i also reduced the cold multiplyer by 50%
