Results 1 to 9 of 9
Thread: LS 2 Twin Turbo Change from LS2 MAF to LS7 MAF.
    May 2009
    19
    Has any on running TT changed from LS2 MAF to LS7 MAF. LS2 maf is ok on 9 psi 12-13000 Hz but if I go to 13-14 psi maf Hz hits 13-14000 Hz and gets lean. I have heard it is no easy task to do this change since this is turbo 2005 C6 Corvette. Is there any one out there that has don this? If so can you give info on Hz table so I will have some start point?
    Jun 2005
    Southern FL
    2,044
    What do you mean not easy to do? It's a MAF, so dialing it in is easy. However, the LS7 sensor does not give you more "headroom" in and by itself. You have to use it in a larger housing to gain that.
    Also, we need to know what TT system you're running, & then we need to see pictures of where your MAF is now, & what size piping is mating up before/aft of it.
    Furthermore, if you are hitting over 12.2k Hz you are pegging the table, so not sure why you mentioned it's okay up to 13k.
    Formerly known as RWTD
    Toys: '22 Tesla Model S Plaid / '20 Chevy Duramax / ?20 Sea-Doo RXT-X (2)
    I had a car with F1-C with 402ci in it and we used the 80lb injectors on it with LPE 100mm MAF on 4 inch tube and till 12 PSI we didn't have any problem with maf . i don't know what is going to happen if we are going to push little PSI on it .that what i would like to know about it if any one tried it before.. The problem is that 2006 C6 doesn't have 2.5 bar OS available yet for it .
    May 2009
    19
    I have APS C6 Turbo kit. Maf i´m planing to use is 100mm made for stock LS7 maf sensor. I was told if I change from stock Maf to 100mm LS7 Maf them I need to start from sero with me tune.
    May 2009
    19
    Quote Originally Posted by RWTD View Post
    Me tune is ok on 9 psi at 12,2k Hz But 12,2 is the higest point I can change so if I lift that up to get fuel for 14 psi I will be to ritch on 9 psi.
    Mar 2016
    12
    Quote Originally Posted by Ingo View Post
    I know this is a old thread but hopefully this helps anyone just doing this now.
    You can put in a z06 cold air intake and a ls7 MAF and a ls2 to ls7 harness adapter. Then get a stock 06 or 07 LS7 HP tune file from the repository and copy all the MAF tables. And temp tables and it will run. From there you can maf tune to make it fly.
    Nov 2009
    All Around
    3,149
    your have E40 PCM easiest OS to work with 2 BAR OS
    screw the MAF and go SD
    my info in sig if you need help
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Agreed. Ditch the MAF.
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
    Tuning Addict
    Jan 2015
    6,813
    Yes, even if you get it dialed in 100% correct - the blow off valve WILL screw with it and possibly cause problems - even if it is far enough from the MAF... There's a reason why the OE has gone back to speed density even on the OE platforms when turbos are involved or at the very least are running multiple MAFs...
    ~Greg Huggins~
