using 2.23. I have read and tuned several 09's in the past two weeks but this 08 will not read. Is there anything else I should try.
screen shot attahed
screen shot attahed
what about trying to do a complete re-write? or doing it in lo-speed instead of hi-speed?
i figured you did, just had a friend of mine suggest trying that. with my luck, of course theyre gone!! haha
Sounds like the vehicle was previously tunerlocked to me.
it was locked before, but i sent it back to the previous tuner to have it unlocked and returned stock. the lady at the shop who i used to use assures me she returned it all back stock and unlocked it, but i guess something could have been messed up in that process...
Tunerlocking generally consists of the tuner changing the seed/key so other tuners cannot access it using the generic key...there are roughly 65000 different combinations so its a pretty decent lock.
When you come across a tunerlocked pcm you will get an invalid authorization codes error upon reading ie you cannot read a tunerlocked pcm...if you could read a tunerlocked pcm it kind of defeats the purpose.
new pcm installed from gm. everything works great now. thanks guy's
I had the same problem on my never tuned 2010 Camaro.
2006 Ram SRT 10 / 2010 Camaro 2SS
