Results 1 to 4 of 4
Thread: 77%?
    77%?
    i have a 05 mustang gt manual and just out of curiousity, what is the tps supposed to read at WOT? i know on a lot of cars it doesnt read 100% but mine only goes to 77%. its probably nothing but im curious to see what its supposed to be, thanks.
    Jun 2005
    Southern FL
    2,044
    It's read off of a % of 5 volts, so if you're hitting 4.1x volts when pedal position is at max, then that would be 82%. I generally see around 77x counts range on the Mustangs at WOT, so that would equate to approx. 3.8 volts, which would be approx. 76% throttle, so I'd say you're perfect.
    Keep in mind, there is a "Max Throttle Angle vs. RPM" that can/will limit you. Most on the Mustangs show this (just set the entire table to 82, if you haven't already):
    Code:
    RPM	Throttle Angle
    800	40.000
    1000	44.000
    1250	52.900
    1500	62.600
    1750	70.000
    2000	75.000
    2250	79.300
    2500	82.000
    4000	82.000
    5500	82.000
    6000	82.000
    6250	82.000
    6250	82.000
    6250	82.000
    6250	82.000
    6250	82.000
    Formerly known as RWTD
    Toys: '22 Tesla Model S Plaid / '20 Chevy Duramax / ?20 Sea-Doo RXT-X (2)
    thanks for the info. i took of my intake tube and watched it with the key on and it looks like it open all the way so i think im good, just curious.
    btw i should have listened to you about not buing long tubes if im under 500hp. i put on pypes LT's and didnt make the car anyfaster at all. i had to add almost 10% fuel in some places to richen it back up to 12.8 so i figured i would have to gain something but nada. dissapointed. ill be doing the comp stage 2 nsr's next week so that better get me some good power.
    I usually look at actual throttle angle pid (in degrees) to know what an 05+ car is doing.
    Justin Starkey
    Ford and GM custom tuning
    Mobile Dynojet 224xLC
    www.VMPTuning.com
    2006 F250 CC 6.0L 14.3@92
    2006 Mustang 4.0L Vortech 15psi 395rwhp wife's car
    2000 Mustang 3.8L TT [email protected] 450rwhp
