Page 17 of 17 FirstFirst ... 71314151617
Results 321 to 334 of 334
Thread: EQ <> VE Version 3.5
  1. #321
    Quote Originally Posted by ktoonsez View Post
    Does it happen immediately when you click "Generate"? If so it sounds like you didnt install the C++ runtime. It works for me in 2.24, 2.25 and 3.0.
    yes it happens immediately. can you explain what the C ++ runtime is?
  2. #322
    Tuning Addict
    6,815
    It should have been one of the lower downloads - I think....
    ~Greg Huggins~
  3. #323
    May 2008
    Chandler, AZ
    537
    Quote Originally Posted by andrew1988 View Post
    Its right in the #1 post of things to install, you need the .NET framework 4.6 and the C++ runtime. All of that needs to be installed for the program to work.
    ____________________________
    2008 Convertible Corvette
    Haltech CAI | Kooks Headers and X-pipe | 227/231 .613/.617 lift 115 LSA CAM | Tuned to death
  4. #324
    ill try that and give it another go. thanks guys
  5. #325
    Sep 2016
    25
    Sorry for the ignorance here...
    I have the .NET already, but the C++ link provided is not found?? I am not very computer savy so could someone point me in the correct direction with a new link
  6. #326
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
  7. #327
    Sep 2016
    25
    I am having a problem with the software tool to regenerate the equations on my 2014 LS3. I use the software to pull the equations form hptuners and create the LS2 VE table no problem. I then send the LS2 VE table to the Lo Altitude VE table with no issue. I am able to tweek the tablw just how i want it and then use the software tool to pull that adjusted table back in the software. I then recreate the equations and send it back to HPTuners. all seems well. However for kicks i zero out all the info in the software tool and repull in the new updated equations from hpt, i then create the ve table from those and that version of the VE table is all out of wack, huge spikes all over the place and nothing even close to what it should have been. Anyone else have this issue?
  8. #328
    Oct 2016
    12
    Can someone help me out real quick, My "VE Reversion Lo Altd" table references RPM an Throttle position not RPM and MAP. Tried using V4 but I can't get past loading the second VE table. Running a 2008 E38 with an LS7.
    Searched through this whole thread found nothing. All the other E38 base tunes I have show the same thing for the "VE Reversion Lo Altd" table RPM/TPS.
    I'm totally lost now
  9. #329
    Jan 2017
    3
    Quote Originally Posted by MinimumJargon View Post
    I'm also having this exact issue
  10. #330
    Sep 2015
    38
    download link not work
  11. #331
    Mar 2017
    Ft. Lauderdale, FL
    95
    2007 Z06 (E38 ECM), stock LS7 short block, .030" milled/ported heads, PLX SM-AFR, MPVI Pro
  12. #332
    May 2017
    7
    Im sorry if this has been covered, but I have not read the entire thread. Everytime I try to apply the data from the graph in the scanner, I am told that the histogram cannot be found. Any input?
  13. #333
    Senior Tuner mowton's Avatar
    Mar 2007
    Florida
    3,773
    Quote Originally Posted by FRICKIN-FRISBY View Post
    Quick question, what version Editor are you using? Since 3.0, HP Tuners has provided a built in VE Coefficient Calculator....you can get to it through the Edit Tab in the editor....
    Ed M
    [email protected]
  14. #334
    Jun 2018
    6
    it was a good read from page one 1 here i do see my question already being asked without prevail, here is some data regarding "couldn't find one equations window" the P12 GM ecu for colorado and hummers only have 5 ve maps and i have opened every other window and tried it, with no success moreover i can successfully get ve calculations on an oem 5.4 Triton also ls3 tune file. finally i am running ecm editor v4 and still no option to tinker with ve maps then previous versions of hence editor for this particular ecm. Untitled.png
