I need a file for a 4l80e with the os# 9381344
If any one has one, PM me
Ryan
Ryan
Pmed.
I need the same file !!! Please pm me
Thank you
I have a 4l80 for 9381344, just email support if you need a segment swapped for that os.
is it possible for someone to send me the same info for os 9381344
Did you have any luck getting it to work with that OS
Tune Repo has this OS available. 2000 Silverado LQ4
~Erik~
2013 Sonic RS - manual, CGM, 6M, sunroof, mods in process
2008 TrailBlazer 3SS AWD LS2, loaded, dropped, modded, SE22 Performance tuned. And then some...
2002 TrailBlazer LT 4WD 4.2L I6, lifted, tires, exhaust, SE22 Performance tuned
How can you find out if your OS/Tune is set for an automatic versus manual? I started out with a 3bar SD open loop OS and a turbo 350. That trans died yesterday (boost spiked to just under 30psi whereas the normal is only 21) and I have a 4L80E ready to go in.
i also need this tune file, os 9381344 for 4l80 swap. thank you
See my previous post for what to search for (2000 Silverado 6.0) and you'll be able to find that file in the HPTuners Tune Repository within your account.
~Erik~
I'm also in need of the same 4L80E Segment file for OS 9381344 if someone can help me out! Thanks in advance!
I believe this is what you want
2011 Camaro 2SS Convertible L99 Bone Stock for now
2003 Dodge 2500 5.9 Cummins QC 4x4. Airaid, 2nd Gen Intake, Grid Heater Delete, D-Tech 62/65/12, Magnaflow. Bully Dog: Propane Injection, Triple Dog W/Outlook Crazy Larry. Edge EZ, BD Flow-Max, 48RE: Sonnax Sure Cure/Transgo combination, Derale turbulator, billet input, Triple Disc, Super servo, 4 ring Accumulator. :beer
