Never Mind
Never Mind
Good reference material on MAP operation.
http://www.aa1car.com/library/map_sensors.htm
Free HP Tuners Beginners Tuning Guide
LS1 Tuning Guide
Michigan Snowmobiler
1969 Firebird: 11.67@114 [email protected] 1/8 1.70 60 ft. EPS cam 234/246 .602.606 114+3, 6.0 LQ4, L92 heads milled 10.5:1, Ported L76 intake, ported 90mm Holley TB, 100mm MAF, FIC Custom injectors, Hooker LT, PYPES dual exhaust with an X pipe, 4L65e with all of the good parts inside, FTI 4000 RPM Stall, 12 bolt with 3.73 gears. HP Tuner tuned by me
2002 6.0L truck MAP. I have the L76 intake.
LS1 Tuning Guide
:ears:
2003 Z06
Forged 347
PTE Billet 67/65 Turbos
FMIC / Dual 50mm Tial BOV's
ID 1000 Injectors
RSI Stage 4 Fuel System
07 Z06 Cam
Tripple Nozzle Meth
ACT Twin disk clutch
25# Boost
Why not just turn off the LTFT's?
LS1 Tuning Guide
If I remember correctly, you have a fairly small cam, why is your idle kPa at 65-67 and 625 rpms? I have a fairly large cam and that is what my kPa is at 850 rpms.
LS1 Tuning Guide
What is your idle timing set at?
Maybe you need to post a tune, log and mods
Something doesn't seem right.
Are you using a wideband on this?
LS1 Tuning Guide
2003 Z06
Forged 347
ID 1000 Injectors
07 Z06 Cam
Tripple Nozzle Meth
25# Boost
