i just got back from the dyno. with the beta software i can not use the bidirection control to lock up my converter but if i use a laptop that does not have beta i can use the manual lock up. when i lock it it shows 594psi of tcc pressure. i am sure it isn't that high but it just lets it goto full line pressure.
i was able to hold lock up on the dyno at wot for many runs. on the last run we saw 635rwhp/600rwtq on a loaded mustang dyno and the lock up sliped for the first time. pretty sure it needs to see more line pressure but i am not sure what values to change for it to see more pressure.
here is my plan for now untill i get some more ideas of what to try.
get an actual pressure sensor installed into the tranny where i can log actual pressure at least at that one access point. then mess with the pressure values and see if there is any effect.
if/when i kill this tranny i want as much info as i can get to help me keep it alive longer next time.
logging actual pressure will not help this lock up issue. i think it is going to take more tables to be able to lock at wot down the track or under 70mph.
The blue line you see at the very end is there because i'm off the gas at that point. it would do that at part throttle as well in 4th,5th and 6th. nothing at WOT though, and i loaded a tune today where i was applying TCC from 3rd gear, and it did exactly the same, saw 0 line pressure, and the slip progressivelly going lower.
if there is no tcc line pressure then the computer is not trying to lock it up.
the slip will get lower based on your tq and rpm. the converter will always be more efficient in the higher rpms.
Well i took another log today from a 3rd to 4th run at WOT in sport mode, and the verter must be locking then because there is line pressure as soon as 4th is engaged. the slip doesn't go to 0 which was my thought when the verter was locked. i basically loaded back the stock apply/release settings. I changed them last month thinking because i've increased the mph shift point for sport mode, that i also had to bump the apply settings to match the new mph shift point at WOT.
It was never locking in 4th with those changes. now it does with the stock apply values.
