Is there a way to convert a tuner cat file .cal to a hp tuners .bin ? So I can use my hp tuners with it.
Not to my knowledge, you might want to ask the guys at tunercat if they can convert their files to bin
start tc's WinFLASH then push control and T, this will give you the test option, select it and select save flash image, then do your normal pcm read, this will give you a .bin file to work with.
2010 camaro L99, Magnacharger TVS 2300, 415ci LS3,Kooks long tubes, yank ss3200, 3.73 rear
I doubt the user has tunercat, or he would just flash the image and read it with hptuners.
Ryan
