Results 1 to 17 of 17
Thread: mpvi not prompting driver install
    Jan 2010
    North Carolina
    29
    Just got 2.2 standard and can't get past step 2. When I plug in the mpvi, it does not see it and does not prompt for driver install. I've tried both laptop and desktop with same results. I'm running xp. I've tried even pluggin up to vehicle as well-no prompt.
    I need some clarity. Do I need to use the mpvi if my laptop has serial port, or can I plug directly to serial port and comm with vehicle? Do I still need to load drivers when doing this? I tried doing this and still was unable to comm w/ vehicle. Got a comm port not config. Thanks for any help.
    Aug 2009
    Western Australia
    122
    Quote Originally Posted by kevmo777 View Post
    have you tried copying the drivers from your CD to the computer and manually loading the drivers through control panel and taking thme off teh computer?
    06 F6 typhoon, DEKA 60lb, walbro intank, 12psi actuator, 36mm ported internal gate, dump, cat, plazmaman 1100hp cooler and plenum kit... 348RWKW....(SOLD) SAVE FUEL TUNE LEAN AND REMEMBER PING IS POWER!!!*********MASSIVE THANKS TO ROB @ MONSTA TORQUE*******
    Jan 2010
    North Carolina
    29
    No, not quite sure how to do that. I'm not real savy w/ my computer skills. But, if you could send some good instructions, I'd be willing to try. Thanks.
    28,268
    Does your laptop have a usb port? I'm not sure what you mean by " Do I need to use the mpvi if my laptop has serial port, or can I plug directly to serial port and comm with vehicle?" as our mpvi interface uses usb not serial.
    Jan 2010
    North Carolina
    29
    I was asking if the mpvi was required when communicating with the PCM or if it was just a 'converter' converting the signal from serial to usb. My laptop does have usb port. I tried plugging in the mpvi and the green power light comes on, but no prompt on the laptop to install driver. I've verified w/ a mouse that the usb in in working order. I tried plugging it into my desktop as well w/ no prompt. I did find the driver on the cd, but not sure how or where to load it on the hard drive.
    28,268
    Yes, the mpvi is required to communicate with your vehicle, our help file www.hptuners.com/help goes into, in depth, how to use our product.
    Regarding loading the drivers try this
    Connect your interface to your laptop
    Post a screenshot of your USB device manager
    so we can see whats going on in there.
    The drivers just need to be unzipped(I usually just unzip them to the desktop so they are easy to point to when installing)
    Feb 2006
    central michigan
    349
    possibly a bad usb cable.if the computer doesn't see the interface,it wont ask for drivers.
    Jan 2010
    North Carolina
    29
    I need some help with posting a screenshot. My computer skills need some work. Thanks. As far as a bad usb cable, the mpvi power light comes on, so I know that it's not all bad.
    28,268
    http://www.hptuners.com/forum/showthread.php?t=14425
    Demos section covers how to post a screenshot
    Jan 2010
    North Carolina
    29
    Looked up the demos on taking sceen shot-it was blank, but see if this works-
    check the attachment
    28,268
    Is that while your interface is connected to the laptop?
    Jan 2010
    North Carolina
    29
    No,but it dosen't appear to change any if I unplug or plug in the mpvi. Here is one w/ it plugged up.
    28,268
    contact support
    Jan 2010
    North Carolina
    29
    contact support
    Is there a phone # that I can call?
    28,268
    Unfortunately not, its all handled via email since its only me
    Potential Tuner Mark's Avatar
    Jan 2010
    Jacksonville, FL
    8
    i had a similar problem installing mine yesterday i needed to manually install the drivers. it took me about 4 hours to figure it out. there is a thread in the help forum with a video.
    Jan 2010
    North Carolina
    29
    Well I would have thought that with the power light on the mpvi interface coming on when I plug it up to the laptop that the usb cable was good-WRONG. Changed the usb cable and everything worked good, drivers loaded great. Just glad it was somethin simple!!!!!!
