STOCK TUNE EXCEPT THE AFR IS SET AT 14.4 I believe.
I reset fuel trims via unplugging the battery for 45 minutes.
JUST changed O2s... Kind of worried about the passenger's side o2 - is it okay?
which would it be B1 or B2? Reason I'm worried is I got a little oil in it.
I'm not able to start. Usually it will turn on if the MAF is plugged in but it wont now.
Scan is with maf plugged in.
If the starter is turning the engine @ 150 rpms is that too low?
I think I'm lean.. am I right?
Help me get it started!!
thanks
