SRT-4 Stage 1 and 2 Injector values
Does anyone have the injector values for the SRT-4 stage 1 and Stage 2 injectors in the Dodge format?
Mainly the Fuel Mass vs. Pulsewidth tables and the Fuel Injector Offset vs Battery Voltage.
If so, could you post them or send them to me? It would be very helpful.
Be careful with the slope values on these NGC cars, or any Chrysler function for that matter. If you look, you will see that amount of usable function data varies between different calibrations. The problem is, there is a header before the first byte of data that specifies how many of the available data point are going to be used by the ecu. Unfortunately neither Diablosport or SCT has a way of editing or displaying this parameter. SCT seems to edit some of their table data so that only the used values show up. You can see the issue if you just copy and paste from one function to another of a different length.
- Chris
www.dcperformance.com
Hexdummy, could you please email me a copy of this spread sheet as well?
[email protected]
Thanks!
