Hi guys I need some help,
I am getting these codes p0512 Starter Signal Circuit and p0102 MAF or VAF A Circuit Low Input on my LS3 swap using a GMPP E67 ECM.
Here's the scenerio. I connect the battery, and crank the engine and it starts for about 3 seconds, the rpm goes up to 2000 and it shuts off.
after it shuts off I try cranking it again and it wont start.
I then check with a noid light the injectors and nothing blinks. also now I have no spark either.
But if i disconnect the battery and reconnect it and try to crank it, the engine runs again for like 3 seconds and then shuts off.
this is a GMPP LS3 E67 ECM it shouldn't have a VATS in it.
it feels like to me there is something turning off the spark and injectors in the ecm.
I also have a HPTuners
how can record those 3 seconds on my hptuners?
