Page 2 of 2 FirstFirst 12
Results 21 to 30 of 30
Thread: 6L80 durability?
  1. #21
    Advanced Tuner madvette08's Avatar
    Jan 2009
    Tampa, FL
    427
    Quote Originally Posted by camaro1 View Post
    someone needs to come out with a custom O/S for the tcm, something that eliminates all the adaptive learing and get the trans control back to the basics!
    Is not that easy on a clutch to clutch transmission, GM ran into alot of problems trying to come up with the calibration to control it.
    2008 Corvette A6 - Comp Cams 231/239 617/624 109 ICL 113 LSA, Patariot Extreme Dual Springs .660", Milled .30" Stock LS3 Heads, Mahle -4cc pistons, FTI 3600 Converter, 1 7/8 kooks cat-less 3 inch X-Pipe, air raid intake, ported TB, SLP Loudmouth I. 512hp/464tq
    2011 Ford Taurus SHO - stock with just a Tune
  2. #22
    Jun 2010
    1
    I have a chance to get a 6L80e and need to know if it will fit behind a Gen IV 454 big block Chevy bored and stroked to 489 with aprox 560 ft lbs and 530 hp? What will I need to fit it? Flex plate, torque converter, internal beefing, rebuild ect.? I am planning to put it in My 67 Impala.
  3. #23
    Dec 2007
    776
    Quote Originally Posted by 489impala View Post
    At this point......without an Gen IV LS EFI engine and the right engine controller (E38/E67) it will not run...apart from in permanent 3rd gear and badly.
    That may change in the near future though....
  4. #24
    Dec 2007
    776
    Search for info on here posted by "thesubfloor". He runs an LS7 Vette that runs hi 9's lo 10's NA with a [now] built 6L80E. Well over 100 runs on the same build.
  5. #25
    Sep 2007
    393
    Quote Originally Posted by LSX378 View Post
    280 to be exact as of July 3rd before my motor let go.
  6. #26
    Dec 2007
    776
    Quote Originally Posted by thesubfloor View Post
    Very impressive performance from the trans Chris. Sorry to hear about the motor exiting stage left. How many runs on the motor? What let go?
    There you go trendsetters: 280+ runs on a 6L80E. With ~700Hp at the flywheel turning hi 9's lo 10's. And super consistent bracket times to boot.
    Just like PG's, TH400's, 4L60's blah blah didnt hold any power until they were toughened up by the aftermarket and dedicated racers searching for results.
  7. #27
    Sep 2007
    393
    Thanks, but like they say "it didn't owe me anything" as I got just under 500 runs from it. I lost 3MPH by the 1/8th mile on my 4th pass that day and I was honestly hoping it was a valve spring issue but when I tore it down I found a crack in the number 5 cylinder.
  8. #28
    Dec 2007
    776
    700HP 500 runs. Cant complain about that. Stock LS7 liners? Crack in the thrust side vertically or some other crack?
  9. #29
    Jan 2006
    Collinsville IL
    697
    Stock trans here at 30k been through 30-40 bottles and ditched that and now been boosted for a month or 2.
    https://www.facebook.com/tuningbyshanehinds
    [email protected]
    2009 G8 GT [email protected] 1.60 - Sold
    2008 A6 LS3 C6 Cammed [email protected] 1.44 Sold
    2013 CTSV wagon 9.21@151
    2015 C7Z bolt ons 10.0
  10. #30
    I found that the durability of the 6L80 is actually pretty good. Mine lasted a LONG time before having to replace it.. I just got a new one from these guys https://reman-transmission.com/trans...des/?code=6L80 and she works like a charm. Just had to take it to the shop and have it installed and now im sittin pretty
