Hi to all,
I have a problem with my transmission on G8 it use full line pressure all the time, I have a code ( something wrong with the input speed sensor and it is illuminating the check engine lamp) I went to shop and they say nothing wrong with the trany the problems is from the ECU which I have change it but no luck.
The trany has transgo shift kit installed.
My question is how can I eliminate this code or how can I prevent the trany from using full line pressure.
I disabled the Max pressure under the invalid torque signal under trans dignos but still no luck.
One last question what would happen if I apply the TCC in the second gear ( is it gonna damage the trany)
