Results 1 to 9 of 9
Thread: torque management
    torque management
    i am posting a stock tune and one with torque management disabled can anyone take a look to see if i did torque management removal right right? 2003 chevy express van 6.0 4l80e
    Under TM, on the ETC TPS Max set this to 100% in all cells. Under Abuse, set the mph to 0 and rpm to 6000.
    That should finish you off on TM only. However, I would leave 5% TM in the transmission on 320 ft lbs up just in case.
    thank you i changed those files. what do you mean 320 ftlb up? ("However, I would leave 5% TM in the transmission on 320 ft lbs up just in case")
    On the 1-2, 2-3, 3-4 shift from 320 ft lbs of torque and up...just put 5 in all the cells which would be 5% TM to longlife of the transmission.
    got it all changed. thanks alot
    No problem.
    Dec 2009
    Edinburg, Texas
    130
    Did you feel any off a difference?
    little bit better off the line and seams better on highway, i am chasing down some part to 1/4 throttle misfires in two cylinders right now so i dunno how much better it is going to be yet
    with all cylinders running good now there is a big difference as soon as you step on gas much more throttle responce, better on highway to. i ended up copy and pasting the tow/haul tables into the normal tables. couldnt stand the trans shifing into od at a very low speed then downshifting very time i gave it more gas
