Page 1 of 2 12 LastLast
Results 1 to 20 of 30
Thread: J1850 Data Question
    Feb 2010
    21
    J1850 Data Question
    I understand that early 00's GM vehicles(Corvette in particular) use the 1850 class 2 bus for a lot of the PCM/BCM and instrument cluster data. My question is, does the instrument panel continuously query the PCM for fuel/water temp/etc data? Or does the PCM transmit this data continuously without being requested?
    If the instrument cluster requests this data, is the data stream look the same as if you request it with a scan tool, other than the source ID?
    Mar 2010
    San Diego
    5
    Quote Originally Posted by matthud View Post
    Can someone tell me where I can find the messages sent to the instrument cluster on the J1850 class 2 bus? I am specifically interested in the messages sent to the Corvette HUD unit.
    Thanks,
    -Scott
    Dec 2007
    776
    Quote Originally Posted by scott451 View Post
    Thanks,
    -Scott
    What year Vette? In any case the messages are continously broadcast.
    Generally the data is in "proprietary" message formats and contains exactly what is required for the specific address.
    Feb 2010
    21
    1998
    Dec 2007
    776
    1998
    Ok then you will probably be fine with some J1850 compatible hardware to listen to what is on the bus and figure out what is what.
    Feb 2010
    21
    Unfortunately I don't have a vehicle to sniff on. I just have the gauge cluster that I am planning on using in a project vehicle that uses a standalone ECU.
    Dec 2007
    776
    Connect them up and cross your fingers . If the standalone ECU is the same or similar year GM.
    Feb 2010
    21
    Quote Originally Posted by LSX378 View Post
    Nope, the ecu does not follow the J1850 standard. Which is why I need to know the commands so I can process the ECU data and output the data to the cluster in the J1850 format.
    Mar 2010
    San Diego
    5
    It's a HUD from a 2005 vette that I am trying to interface to another vehicle. I don't actually have the vette. I was hoping to use some ELM322 based tool to collect the J1850 commands from a vette.
    I can probably get access to a Vette, but is the instrument J1850 (class 2 serial data) the same bus that is on the OBD-II connector? If no, where can I tap this bus without tearing apart the car?
    Actually, the only proprietary message I'm looking for is the one that the vette sends to tell the instruments (and/or the HUD) that the car on. The HUD won't powerup without it. all other signals are direct wires (e.g. speed, rpm, etc).
    Thanks,
    -Scott
    Dec 2007
    776
    Thanks,
    -Scott
    Have seen class 2 on pin 2 on the OBDII connector. With any luck it will be consistent on all GM platforms.
    Mar 2010
    San Diego
    5
    Can anyone post/or pm a raw ELM32x capture of the GM instrument J1850 (class 2 serial data) bus or pin 2 of the obd-II connector from a 2002 or later GM vehicle? Preferably a vette.... I only need the first 30 seconds, when the car is first turned on...
    Thanks,
    -Scott
    Apr 2003
    Almost 2000 feet.
    7,876
    Thanks,
    -Scott
    05 and later Vette was CAN bus.
    Always Support Our Troops!
    Mar 2010
    San Diego
    5
    Quote Originally Posted by EC_Tune View Post
    OK then the HUD came from a 2003 vette. It's J1850. the can bus pins on the controller are not connected and it has the xc68HC58 interface chip to talk j1850.
    Feb 2010
    21
    I was able to find the message formats in the SAE J2178 books, and I am able to command the fuel level, oil level and water temp. But about 5 seconds after I command it, the gauges go back to the failsafe position. This is on a dash that is not connected to the pcm or any other serial 2 device. I believe its because the gauge cluster knows there is no pcm present, and this lack of comm causes it to reset the position. Does anyone know of a way to emulate enough of the pcm messages to the gauge cluster to trick it into thinking it is there?
    Mar 2010
    San Diego
    5
    Cool. What hardware / Software are you using to send the J1850 commands?
    Dec 2007
    776
    What terminal program are you using? Will it send a text file?
    Feb 2010
    21
    elm322 and a python script I wrote.
    Dec 2007
    776
    So you can use python to run a script to send the message at a one per second rate?
    Feb 2010
    21
    Yes, it basically automates the ASCII strings that you could send from Hyperterminal, loops them once every so many seconds to keep a steady display.
    Dec 2007
    776
    so you are all set to go .
