'99 S10 4.3 with SyTy turbocharger
Running (88k mi) 33# SyTy injectors
Idle, part throttle and minimal heavy throttle runs are great.
But once under load, 2nd gear accels, and it starts to reach
3,000 RPM and up, it leans out seriously bad.
I'm running a new Walbro 255 fuel pump. I just replaced the
fuel filter. And fuel pressure at idle w/ vacuum is 48 psi, and
58 psi w/o vacuum (in case that matters).
My PE tables are getting very high compared to stock, and it
doesn't seem to knock down the lean AFR at all.
At this point I'm thinking something else is wrong, but the only
thing I can think of is the injectors are bad. Does my situation
seem like a scenario for old, dying fuel injectors? I purchased
them used, supposedly "working fine" says the seller, and with
88k miles on them.
I have a new set of Mototron 60# injectors that I will try as a
replacement, but before I go through the effort I was curious if
my problem sounds like a sign of something else? Or if swapping
injectors seems like my best course of action?
