Hi all,
im having some trouble with the tune in a 2004 BA XR6T A4, it has an APS stg 3 kit 60lb deka's 12psi actuator, (which will not drop below 24psi!) and a 4 inch zorst.
The problem is that it will not stay in closed loop fuel controll, it will go into open loop and then closed loop whenever it likes to, i cant really pin point exactly what conditions it does it in, though it does seem like it happens when cruising.
The other issue im having is the injector flow rate value, between hi and low there is a pretty big difference, does anyone have the correct values for the injector flow rate?
FWIW the car was previously tuned with sct.
Thanks in advanced.
