Results 1 to 5 of 5
Thread: Checkbox for Reset LTFT's
    Since Flash doesn't reset LTFT's on flashing, can we get an optional check box to have the program reset the ltft's.
    Just want to keep with the fact that we do all of our work witout opening the hood!
    Thanks a bunch..
    Re: Checkbox for Reset LTFT's
    we are working to have this feature in the scanner.
    Once it's in the scanner would that be adequate? I mean once you make a change to your Injector Flow rates etc. the next thing you want to do is start the scanner right?
    Thoughts?
    I count sheep in hex...
    Both would be best, but typically you only reset it when you load a new tune. So I would give preference to the flash program.
    Quote Originally Posted by brianw21
    my point is that the next thing you do to see the effect of your new tune on the LTFT's is to start the scanner, where you will be able to easily reset your LTFT's before you start logging.
    Either way 8)
    Maybe both ;D
